U4GM ARC Raiders Alarm Clock Item Guide
- Blustery
1 mes 3 días antes #60955
por Blustery
U4GM ARC Raiders Alarm Clock Item Guide Publicado por Blustery
An Alarm Clock doesn't look like much when you pull it from a dusty flat or a half-looted bedroom, but in ARC Raiders, small finds often matter more than they first seem. If you're sorting loot, crafting parts, or checking
ARC Raiders BluePrints
before your next run, this little household item can still earn its place in your bag. It won't heal you, stun an ARC, or win a firefight. What it can do is feed the recycling loop, and that's where its value starts to show.
Quick Loot Notes
The Alarm Clock is best treated as scrap with a purpose. You pick it up, carry it out if space allows, then break it down once you're back at a station or safe crafting point. It's not the sort of item you build a raid around, and that's fine. ARC Raiders often rewards steady habits. One clock won't change your loadout. Five or six recycled odds and ends might help you finish an upgrade you'd otherwise be short on.
Where You'll Usually Find One
Residential zones are the first place to check. Think bedrooms, side tables, shelves, kitchen counters, old storage boxes, and apartment interiors. If a room looks lived-in, or used to be lived-in, it's worth a quick scan. Don't spend too long staring at every corner, though. Other players may be moving through the same buildings, and the noise of a fight can turn a quiet loot route into trouble fast.
Alarm Clock Value at a Glance
CategoryDetails
Combat valueNone, so don't keep it over ammo, meds, or key tools
Crafting valueUseful when recycled for basic materials
Best moment to lootEarly raid, when your backpack still has room
When to drop itWhen you find rarer gear, mission items, or better trade goods
How to Handle It During a Raid
A good rule is simple: grab it if your bag is light, ditch it if the run turns serious. Players often make the mistake of clinging to every recyclable item, then leaving behind something far more useful. If you're close to extraction, keeping an Alarm Clock makes sense. If you've just found a weapon part, rare component, or survival item, the clock should probably go. It's useful, not sacred.
Final Thoughts
The Alarm Clock is a small reminder of how ARC Raiders handles loot. Not every item needs to be flashy to have a job. Recycle it when you need materials, sell or trade other spare goods when currency matters, and keep an eye on resources like ARC Raiders Bp for sale if you're planning builds outside the raid itself. Used sensibly, even basic junk can support better gear, cleaner prep, and safer runs.
Quick Loot Notes
- Item type: miscellaneous recyclable loot
- Best search area: residential buildings
- Main use: recycling into crafting materials
- Pickup priority: decent early in a raid, lower when space gets tight
CategoryDetails
Final Thoughts
Tiempo de carga de la página: 0.151 segundos
