arc raiders lure grenade bp
- eVELyncLaRk10
1 mes 2 días antes #60958
por eVELyncLaRk10
arc raiders lure grenade bp Publicado por eVELyncLaRk10
In ARC Raiders, survival hinges entirely on controlling the battlefield. When you find yourself cornered by mechanized squads, raw firepower isn't always enough—you need to dictate where the enemy looks. That is where the Lure Grenade comes in. This Uncommon utility item changes how you handle intense combat and extraction zones. However, getting your hands on one permanently requires completing a demanding multi-map quest and knowing exactly how to craft it.
The Key to the Bait: "Greasing Her Palms"Unlike generic loot that you stumble upon randomly in broken crates, the Lure Grenade Blueprint is a guaranteed reward tied directly to progression. You unlock it by successfully completing the quest "Greasing Her Palms", handed out by Celeste.
This quest isn't a walk in the park; it demands a full tour across three distinct maps, forcing you to risk your gear in high-traffic zones:
Dam Battlegrounds: You must bring the Dam Surveillance Key into the Water Treatment Control building and unlock the room on the south side.
Spaceport: You need to navigate outside the Rocket Assembly and scope out the massive rocket thrusters.
Buried City: You are required to climb up to the 6th floor of the Space Travel Building via stairs or elevator shafts to examine a barricaded area.
Because this quest requires three separate extractions across completely different environments, it represents a significant time investment. Once you successfully turn it in, Celeste rewards you with the permanent blueprint along with 3x Speaker Components and 3x Electrical Components to get you started.
A Common Workshop MistakeOnce you safely extract and complete the quest, a common point of confusion arises for many Raiders. You open your inventory, confirm you have learned the blueprint, and walk over to your Explosives or Grenades Bench—only to find it completely missing.
This isn't a bug. Because the Lure Grenade functions as an aggro-manipulation device rather than a lethal explosive, the game categorizes it as a gadget. To craft it, you need to head over to the Utility Bench (or Utility Station). Keeping your workshop organized and knowing where your schematics live will save you from frustratingly scrolling through the wrong crafting menus between raids.
If you ever find yourself struggling with difficult quest chains like this or simply want to optimize your loadout without the brutal grind of multi-map extraction missions, utilizing trusted third-party marketplaces can save you hours of frustration. For instance, players looking to skip the RNG and heavy extraction risks often rely on external platforms to get ahead. You can look into specialized gaming platforms like U4N to buy arc raiders blueprints safely , allowing you to bypass the standard progression loop and immediately add high-tier utility to your stash.
Item Stats & Economic BreakdownThe efficiency of the Lure Grenade lies in its exceptionally low crafting overhead contrasted against its massive area of effect.
The Recipe: 1x Speaker Component + 1x Electrical Component.
Crafting Duration: 15 seconds.
Effective Radius: 50 meters.
Duration of Effect: 15 seconds.
From an economic perspective, this is one of the most cost-effective defensive tools in the game. It uses zero rare metals or advanced chemicals. Speaker and electrical parts are common tier-1 scrap items found in almost every building. For the price of two basic inventory slots of junk, you create a device that commands a massive 50-meter radius for a full 15 seconds.
Tactical Application and Matchup AnalysisThe Lure Grenade functions as a sticky device. You can hurl it onto a wall, the ground, or directly onto an elite machine. Once it lands, it emits a loud, high-decibel audio signal that overrides the target programming of nearby ARC units, forcing them to turn their weapons toward the source of the noise.
In practical terms, this gives you a critical 7-second window right at the start of the distraction to line up flawless weak-spot shots or safely plant heavy explosive traps like Deadline Mines.
Let's look at how it performs against specific heavy threats:
Bastions and Bombardiers: These slow-turning, heavily armored units are highly susceptible to the trap. Tossing a Lure Grenade to their left forces them to expose their unshielded rears, allowing a teammate to melt their power cores.
Rocketeers: A well-placed lure completely diverts their missile barrages away from a downed teammate, buying you the exact amount of time needed to execute a clean revive.
Shredders: Warning. Field tests show that the Lure Grenade is highly inconsistent against Shredders. Their aggressive, fast-moving melee tracking often causes them to ignore the audio distraction if they have already locked their sights directly onto a sprinting Raider. Do not rely on it as a panic button if a Shredder is already in mid-charge.
Ultimately, the Lure Grenade isn't meant to kill enemies—it's meant to buy you time. Whether you use it to slip past a deadly patrol, redirect a boss machine, or secure a tense extraction while the countdown clocks out, mastering this 50-meter distraction tool is one of the smartest upgrades any Raider can make.
Tiempo de carga de la página: 0.148 segundos
